Is my 15HP Merc undersized for my boat?
Less Nessman
I have a 14.5 length princecraft resorter (Center Line : 4.4 m (14'-6"), Beam : 1.9 m (73")) with a 15hp Merc, rides great with two adults, but doesnt plane with just me.
Is the motor undersized?
Can I add weight to the front end between the peak and front seat, using what? bag of sand?, pails of water?
Thanks
Huron Angler
Re: Is my 15HP Merc undersized for my boat?
Try placing a large cooler full of beer/food/etc and ice in the bow and see if that doesn't level her off a bit.
More practical than sand.:D
Bob_VT
Welcome to iboats.
Have you tried adjusting the trim angle when you are alone?
Try one more notch in or one notch out since you have changed tha balance when you are alone.
Huron Angler
To answer your question directly I believe that you may want to go a little higher on the hp as that boat is rated for at least a 40hp by the coast guard.
The 15hp puts you at 20% of the rated power(if it is 40) which I would consider low.
What is it rated for? Is the plate on the boat somewhere?
Less Nessman
thanks for the information it has really helped!
Lester
