Re: Is it possible to replace the timing cover on SBC w/o dropping the oil pan?
When I slip the seal installation/alignment tool over the crank and on the seal it seems to slip right over the seal and fits perfectly flush and centered.
The last time I pullled the balancer the seal was not damaged, although it was still leaking profusely. How can I test for excessive crankcase pressure?
Again it only seems to leak when the engine is under load at cruise speed, would that indicate a crankcase pressure problem?
OK.. sounds like you have crankcase ventilation covered.
By the sounds of the reman tag, the crank installed was either pristine, or new.
Is there a possibility that the timing cover is not holding the seal square to the crank? In other words, either the cover was stamped incorrectly, or is pushed in, and the seal is biased in one direction. Do you happen to notice 1 part of the seal getting chewed up in peticular (top, bottom, left, right) or is it pretty much the entire seal getting chewed up equally?
