patternghost
- Sep 9, 2010
- 9
I have a boat with a 70 HP 1978 Johnson. I got it out last week, cleaned the boat, charged the battery, and tried to start it in the driveway. The key turned but nothing engaged. No auto choke, no starter, nothing. I didn?t have time to mess with it so I let it go.
Yesterday we took the boat out on a pond and played around with the trolling motor. I went out today and for fun turned the key on the 70, and it started! I shut it off, then tried again, worked again. I hooked up the water muffs and tried again, and this time no power to anything.
I have checked the fuse on the motor, cleaned the plugs in the big red connector, made sure the battery is good, made sure it?s in neutral?
Is there some other trick I should try before I start inspecting wires or replace the key switch?
Thanks!
Thanks!
