Is it hard to change the tiller handle??
tonypizza
just change my dt25 suzuki 1984 for two 35 hp johnson.One is with the electric starter long shaft 1977 and the other is a 1979 short shaft with tiller handle manual start.They are both in a good shape .I want to put the tiller handle on the other one .Is it hard to change the tiller handle??thank you..
G DANE
Re: Is it hard to change the tiller handle??
The bracket for the tiller is a part of the steering bracket. They are interchangeable, you might have to let the pivot shaft follow the bracket that holds the tiller.
Difficult ?? Depends a lot of if it is salt water motors. The long bolts that holds the two parts of the lower mount around the midsection occationally breaks, apart from that usually no problems. You only have to part the lower mount, loosen the mount from the pivot shaft in buttom and remove the 3 nuts for the upper rubber mounts, then you can wiggle the whole bracket from the motor with the motor resting on its back on a workbench or the floor. Maybe its best to remove the vertical shaft from the tiller gear to the armuature plate first. Go for it !!!
tonypizza
Fresh water only.Tomorow i will start on it and let you know how it went thank you guy"s for the info...
