You could and some do, With or without you still have to cut the wood flooring so the boat sides gently touch the boards to keep them form sliding around. Sand the edges well and I put a strip of duct tape all the way around to prevent any sliver damage. The consensus on using both floors however is that adds a lot of weight to the boat in general and the floor specifically. By recommendation, I removed all the slat the OEM floor but the middle one. I cut the floor boards so the seam between the two sections lie on this one board. Using the shell of the OEM floor also protects the actual floor of the boat. Only using one slat takes 20-25 lbs out of the boat which saves propulsion energy, battery or gas, and increases speed. Also, and in my opinion more importantly, it takes stress off the bottom hull seams. With this in mind, I added extensions to my trolling motor wires and stow the battery in the middle of the boat. The key is taking your time and cutting the floor so it's GENTLY snug but not so tight it stresses the floor seams. Scottish posted some cutting dimensions a few pages back which used and were fairly accurate for me though I did have to take some more off the width to fine tune it.
