Re: Intex Mariner 4 modifications and Tips
AStanton: I recommend that when you can afford it you also purchase a power source, as I have, thus freeing you from your vehicle, to inflate your boat. Earlier in this thread (June 28th I believe - pg 10) I posted 3 pix of my setup and in the 1st (left) you can see the Black & Decker 375 amp unit I have. This was $50, and I'd recommend it, but is also able to inflate car tires (on its own). Units without this feature are less expensive. In the photo, my pump is already plugged in.
When I get to the water, I unload everything, including this unit so I do not need to inflate the boat close to the vehicle. I place it in the boat and simply move the pump from valve to valve to inflate the boat. This unit plus the pump goes out on lakes with me and is handy if I want to top up any of the boat tubes, which might be necessary if the temperature drops. Bring along your phone's car charger and your phone won't die while on the water, even if you are using it to play tunes or the ball game.
