LakeRaystown
Thread starter- Joined
- Aug 2, 2012
- 2
I bought this boat last summer. The alternator was shredding belts and not re-charging battery. Ultimately replaced teh alternator and it seems that problem was fixed.
This season, there's a new issue. Two weekends ago, I started up the boat with no problem. We went a few miles and I shut it down for a swim. It started again, but did crank just a little bit. A few miles down the lake later, I shut down and tried to start again and there was nothing. No cranking, no clicking - just dead in the water. The electrical stuff worked intermittently (blower, bilge pump, radio). When the key was on, the guages leaped and jumped up and down a few times, at random.
After the tow, I had a mechanic look it over. He found a corroded ground wire btw. battery and engine block. He fixed it and started it up several times, with no problems.
My co-owner took it out the next weekend and experienced the exact same pattern as me (several starts with no problem, followed by nothing).
The same mechanic started up the boat a few days later, with no problem. He ran it up and down the lake, shut it off and turned it on multiple times - and no problem at all.
Additional facts: the boat sat in a barn for about 3 years before we bought it; and last season, there were a few occasions where I had to jiggle the throttle to get it to start.
I've asked the mechanic to check the throttle safety switch. Any other thoughts or suggestions? Thanks in advance.
