minuteman62-64
Thread starter- Joined
- Apr 12, 2011
- 1,350
1982 Mariner 30 HP. Last three times out had short term overheating episodes.
First time ran about 10 minutes at 3/4 throttle, then coming back into the "no wake" zone the cylinder head temp went up into the 200-220 degree range. Slowed to idle, temperature dropped and made the remainder of the run (maybe 1 hr.) at lower speeds w/no further problems.
Second time at idle at the dock right after launch. Same thing. Temp began rising to the 200-200 degree range. Cut the motor, completed post launch prep, started up and ran for about 2 hours at various speeds, including a short streach at 3/4 throttle w/no further overheating.
Today ran for about 90 minutes at low speed to maybe 1/2 throttle w/ no problems. Ran it up to maybe 2/3 throttle and the overheating began again. Slowed to low speed and then cut the motor for about 2 minutes. Started it up again and had no problems the rest of run (another 30 minutes or so).
Good flow from the tell-tale all the time, even when the temperature was rising.
Impeller is a little over a year old with only about 15 hours on it.
Any ideas where to look for the problem?
