Intermitent blower problem.
type911
Hi names Geof...Just got a classic 86 Sea Ray Weekender as a welcome home from Iraq gift. Loving it minus the gremlins.....
Rundown....Blower not working.
Test Wires with fluke...nothing
test Blower with jumpers
Blower sounds like death.
Pick up new Blower at west Marine.
Clean connections.
Fluke meter and see 12v
connect new blower.
Nothing
Check fuse...Fuse good
Fluke to wires again... No power
Disconnect Blower hit toggle a few times. Toggle lights up
Test wires....12v
Connect Blower........NOTHING!!!!
Fluke.....Nothing.....Debate on taking razor to wrist. J/K
Any ideas?
madman2021
Re: Intermitent blower problem.
sounds like you have high resistence in the wires. if you have a good meter, run an ohm test and check for resistence. chances are the wires are corroded on such an old boat.
produceguy
Welcome home and thank you for what you do.
Just run new wires OR check the connections at the toggle. If that works try connecting the old blower back up and keep the new one or take it back.
Hope it works friend.
Lyle29464
I would jump the switch. It could be the wires but odds are its the switch. The 12Volts you read on the meter only tells you everything is hooked up. A bad switch ( or poor connections)can peg a meter but not let enough current through to run anything.
solar7647
I am a firm believer in when replacing components in your electrical system on old boats spend the extra $10 bucks on the new wire and switch. Much easier and less time consuming plus you get the added satisfaction that you know it will work when you hit the switch, your blower is one of the most important pieces of safety equipment on your boat. Then pull the old wires out so they dont cause confusion down the road.
Welcome home and thanks for your service! Hope you get that thing going and get on the water, you deserve the fun!
The unfortunate result of starting your boat after fueling without running your blower
......this was last July 4th on the river i boat. The guy ran out of fuel and had someone bring him gas and fueled on the water. He didnt have a blower and when he started the boat the gas fumes in his bilge went up. Lucky know one was hurt but the boat was a total lose and it melted the empty beer cans on board to the hull!
royal0014
Master Chief Petty Officer
Welcome aboard, and Thank You for your service!
Ok, start at the begining: use the fluk, power to fuse, power to switch, power to blower.
I'd bet on a bad switch. If you can check the resistance in the wire from swtch to blower. And make sure the blower has a solid ground. Most DC problems are caused by a bad ground.
type911
Thanks All! The boat was rewired in 06. The problem turned out to be a bad switch. I am replacing all of them. I know first hand how important Blowers are. Not to mention being a Coast Guard Boarding Officer.....I better have my own boat up to par. LOL
