FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Oh well. It was worth a shot. I spend a lot of timing looking at those diagrams (and I have only the one Evinrude). I find them to be very enlightening.
Hopefully some of the more seasoned sages around here will have your answer.
yes they are inter changeable you can fit them from i think round about 1972\3 on wards the only thing that you have to change is the connection side of the wires after some years they fitted plugs , cut them off or fit one if it does not have it , the amps rating have also changed a bit here & there but it will still do the job irrespective .
oh ok I just ask because I ride around and it runs fine for about 10 mins then stop and try to restart it then it acts totally different kind of like its flooding. they say the coils maybe getting too hot
First things first, you need to find out if you are actually loosing spark or are having a fuel problem. You are going to have to check the spark when it stalls, if you have good spark pump the primer bulb and see if you are running out of fuel.
If you are loosing spark, go to the CDI website and look up your engine and use the trouble shooting guide to help you find your problem.
If it is an ign prob you'll also need some equipment to do the testing. Start off with an open air gap spark tester which you can buy at any parts house for $8.00. Set it at 7/16 " and check your spark.
