A couple of critical things. The powerhead base gasket is different between a 72 65 hp engine and a later 60 hp version. Which probably means that even if the powerhead would bolt up, the exhaust/water passages are different between the two blocks. Likely they are not compatible. If you were to put the 65 hp gearcase onto the 60 hp, you'd encounter other problems. The 60 hp engine is setup with a mechanical shifting gearcase. The 72 is an electric shifting case-different animal. If you were somehow able to overcome that, then next up: The electric shift gearcase fit would have to be checked: Check the measurement of the two gearcases to make sure they are identical in length, driveshaft to top of the gearbox. Then also check the number of splines/diameter on the engine end of the driveshaft-they may not be the same. Perhaps someone that has tried this can offer their words of wisdom..
