Installing switches
Relliott
I have a 16 ft jon boat with a electric start 25hp on it. I use it for duck hunting during the winter. I am looking to install a switch so i don't have to fumble around in the early morning with unhooking and hooking running lights, q-beam, and interior lights from the battery directly. Any ideas on what would be the best approach?
Thanks
Relliott
Re: Installing switches
which switch would you recommend? I am looking for something simple that I can mount in the back of the boat near the battery.
Thanks
Tash just showed you a whole bunch of switches, any one of which will work. The first one in the picture is probably the easiest to install. Bend a bracket, drill a hole and mount it. A switch is a switch so your choice is push button, toggle, rocker, or push/pull. The net result is the same -- they all turn stuff on and off.
