Installing steel cable to drum and pulley steering system
Bdp35
I am replacing the rope with 3/16” steel cable on my 15ft 1956 wooden boat.
Can I use my old pulleys with this cable?
Please see photo of the U groove measurement of one of the pulleys.
Any advice would be greatly appreciated.
Thanks!
Brian
Chris1956
Honorary Supreme Mariner
Plastic coated steel cable is the standard for those systems. If you boat in salt water stainless steel cable is better. Make sure the pulleys are well secured to the hull. I think the cable needs to wrap on the drum from the bottom. If done the other way, the steering will be backward.
Usually, the HP of the engine would be less than 50HP, with those steering systems, or the motor could wobble port to starboard at speed.
airshot
Bare steel cable would wear out those pullies quickly, but the plastic sheath will prevent that. As long as the cable is not a snug fit into the pulley your good to go. As mentioned, be sure the puppies and springs are well anchored !
