Installing my carb kits
22E6441
So I got the carbs out and started to disassemble them.
I have not removed the main linkage through the throttle body with the butterfly valve, but did take everything else out except for my high speed jets...can't get at them and don't have the tool. They looked pretty gooey though, though I think they've cleaned up well.
I've sprayed out all the passages with carb cleaner spray and nothing was really too dirty as far as appearances went, but everything looks good now. For example, if I hold up the bowls to light I can clearly see light coming through the high speed jets, and it's a nice little circle of light. Looks pretty good. I've sprayed out everything else too.
Can I just blow out all the passages now and start to reassemble, of should I wash it out?
Are these two stroke carbs really as simple as they appear? I feel like I'm missing something.
tashasdaddy
Re: Installing my carb kits
yes they are that simple. if you can see light spray more cleaner thru it, to make sure there is nothing sitting on the other side, to block the pick up tubes, in the center of the upper half, blow them out also. you should be ok.
krogie
sounds like a clean carb to me, like said before give it another look over checking all passages to make sure everything looks good
jonesg
thats what I thought too....
and they wanted how much to do THIS? :p
samo_ott
Yep, it's always harder to re and re the carbs then it is to rebuild em!
