Installing an isolator
Huppe
I'm in the planning stage of installing a 200amp Battery isolator and doing a lot of research. I have a Perko switch right now. I'm running an 2008 350 Merc I/O. My intentions are to replace the switch so i don't have to go from one battery to another. I want a dedicate starting battery and a dedicated house battery. The starter will be a regular marine cranking battery and the house will be 2 kenityk HC2000 deep cycle batteries running in parallel. I'm running a very big setreo system so I plan on upgrading the Alternator from my 65 amp stock alternator to approx 200 amp Alt. My question
- Can I run the negative wires from battery #1 (starter) and battery #2 (house bank) in parallel and use the original ground wire to the grounding plate while using an Isolator.?
All wiring diagrams show sperate ground wires for each battery. I'm finding a hard time locating a secondary ground area given the confined engine area.
I look forward to all your help!!
dingbat
Re: Installing an isolator
I have a ground cable running between the batteries and another connecting the batteries to the engine ground
Boatist
I agree all grounds go to the engine block.
Question I have is what type alternator do you have?
If it is a 1 wire alternator then a VSR relay works better than a battery isolator.
If it is a 3 wire alternator then the isolator work very well.
I would suggest a larger isolator than your alternator output.
nikon
^^ How so? I'm planning on buying one of the two soon, didn't know which one to buy...I have a single wire alt.
