Installing a wakeboard rack without a tower on a Bayliner 175 step-by-step walkthru
klm4755
Enclosed is a step-by-step walk thru to install a wakeboard rack to a 2009 bayliner 175 without a wakeboard tower. My objective was to install a wake board rack that met the following criteria:
1. Was a robust system and could handle the various loads of the boat (not a wimpy design).
2. Could support 2x wakeboards.
3. Would not interfere with the Bimini (in deployed and/or stowed position).
4. Would not impede boarding/deboarding from the dock.
5. Would not interfere with docking the boat (cleat line obstruction, fender placement...).
6. Easy access to board.
7. Would not obstruct drivers view.
8. Functional and clean aesthetics.
9. Quick disconnect feature (no tools req'd would be nice).
I've looked at a few non-tower wake board systems and they are either too expensive or did not meet one or more of the criteria listed above. I bought, from e-bay a wake board rack at $120 sold by e-bay member "lipboating" and seen here:
http://cgi.ebay.com/Quick-Release-R...emQQptZLH_DefaultDomain_0?hash=item2c50779240
the wakeboard rack, from e-bay
closer view, seems like a nice item, aluminum made. The features I was looking for was the ability to attach to a 7/8 inch rod and fully adjustable mounting angles
the adjustable mounting bracket
klm4755
Re: Installing a wakeboard rack without a tower on a Bayliner 175 step-by-step walkth
7/8 clamp in vertical position
7/8 clamp in horizontal position
bracket removed from rack, quick disconnect
klm4755
bimini deployed on boat, the bimini brackets are 7/8.
attach rack bracket to Bimini aft vertical bracket
quick check of rack
Couple of issues:
1. wake board is too far back, would impede entry/exit of boat
2. aft bracket is not all that strong, worry about failure of bimini
klm4755
bracket as clamped to bimini rod
move board to middle bimini bracket
seems better. Can not exit/enter boat with wake board attached except:
1. seems board is too high
2. The bimini support rod system may not be able to support the rack and board
I'll need to fabricate my own 7/8 rod and attach to the boat about this location
stainless steel rod at 6 foot in length, $40 from marine west
klm4755
rod size
use a couple of these stainless mounting bases
vendor markings
mount one here
klm4755
they are pass thru style
mark the spot, center of rail
need to drill 1 inch diameter, need slight clearance size hole, where clearance = Diameter hole > diameter rod
first drill pass
klm4755
final hole size
close-up of 1 inch diameter hole
check base placement
drill holes for base fastener attach
klm4755
all 4x holes drilled
diameter of fastener Metric 4 = .153 inch
drill size .170 inch
use this tool to find grip
klm4755
need to make an Epoxy mix to close-out the exposed fibers of drilled hole
coat the hole with the Epoxy
coat fastener, work in the hole
view from bottom
klm4755
now to make the base, I'll need a non-pass thru style
trim lines
cut with band saw
check hole size with ball gage
klm4755
base plate done
cutting the 7/8 rod to manageable size
deburr end
pass thru rod
klm4755
secure base with stainless steel wood screw right into the boat floor, thru carpet
attach rack
add board
side view
Observations:
The upper bracket seems to be taking too much of the load. Seems to be carrying the moment as a short couple. I'll need to remove the upper bracket and replace with a aluminum guard
klm4755
aluminum sheet to make the guard
template size, based off the bracket
final size, after de-burr guard
installing guard
klm4755
as installed
trim rod again and de-burr
add wakeboard rack bracket to rod
attach wake board rack
klm4755
aft view with wake board attached
forward 1/4 view
forward view
from back left seat
klm4755
from drivers seat, little loss in visibility
rod and bracket with bimini installed
bimini with rack, plenty of room to enter/exit boat
view from back of boat, standing on aft deck
klm4755
wake overhangs enough so no wake drainage will get into boat
fwd 1/4 view
fwd view
side view, room to enter exit boat, does not effect docking of boat
klm4755
bimini stowed, no issues
bimini down, no issues
Review, observations and lessons learned:
1. The 175 does not allow wake board storage in ski locker
2. The final installed rod and attach system is very robust. I can pull my full weight on the rack without rack/rod deflection.
3. Little loss in visibility.
4. No entry/exit issues
5. Although I have not tried out the system, that review will need to occur spring/summer, 2010.
Enjoy,
Keithm
Knightgang
Remeber to keep the bracket location on the Rod a little lower than where it was mounted on the angled Bimi Support, or you will have an issue wit the Bimi deployed...
EDIT:
You were still posting as I was reading and made my post...Good Job. Looks great...
Hit It
Your installation looks great. I've struggled with this issue too, as I don't have the dough to fork out for a tower right now, but still hate having my water toys laying around in the boat. There is a guy on here, sharps45, who makes racks that hook right on the cleat on the side of your boat. That way you don't have to drill any holes or make any modification to your boat. I got a couple from him and they work great. Here's his webpage:
http://web.emerytelcom.net/users/rustut/page1.html
