Installed new head gaskets but they leak
peckulese
I just installed new heads and head gaskets on my 2006 4.3 Mercruiser but there is water leaking into my oil and seeping from the edges. The heads are new and were checked by a local machine shop so I don't think they're warped. I torqued them in sequence and a little at a time exactly as the manual said. I suspect the problem is that I had used permatex aviation gasket sealer on the head gaskets. The manual called for perfect seal but I don't have access to that. The manual also said not to use sealer if they were graphite gaskets but they were not (as far as I could tell). I believe they were composite gaskets. They were covered in a white coating of some sort, almost sticky. I kinda thought they wouldn't need sealer. Do you think I should try to retorque the heads or should I take it back apart and install new gaskets with or without sealer?
The motor had frozen with water in it and broke the heads and exhaust manifolds. Winterizing isn't usually necessary where I live but we had a cold snap last winter that caught me unprepared. I've looked the block over and don't see any cracks. After I put the heads on, it started up and sounded great except for the leaks. Thanks for your help.
MikDee
Banned
Re: Installed new head gaskets but they leak
I doubt it would be the heads, or gaskets then, if you did it right. I think you have other issues with the block, possibly a small hidden crack in a water jacket, or exhaust manifold, or riser.
penst8grad
I'll second what Mikdee said.
If that's not it, look at the boats and bolt holes. If they weren't cleaned you can get a false reading from the torque wrench.
Don S
That composite gasket IS graphite. You shouldn't have used sealer on it.
Were you actually using a Mercruiser service manual. Sounds like an aftermarket manual because Mercruiser doesn't even mention sealer.
Did you use the angle torque method of tightening the head bolts?
Besides that, if you are getting water in your oil, then you also have a very good chance of having a cracked block. Pull the intake manifold and recheck the block above the lifters.
JustJason
I'll 2nd what don says... 4.3s like to crack in the lifter valley area.
Ayuh,..........
Or,......
Opposite the Core Plugs,.. Into the Base...............
