Inside a Mercruiser 165 Manifold
50170
My manifold is bad. I cut it open to see how it is made. I am reasonably confidet I can recreate this manifold at work in mild steel, then rework in stainless. I will also reverse flow and baffle to fix the cracking issue. I am also cutting some weight. I will post pics on my progress.man1.JPGman2.JPG
Bt Doctur
Re: Inside a Mercruiser 165 Manifold
for $489.00 its not worth it
Pete104
+1 for Bt Doc!
But thanx for the insight.
kmarine
I recomend looking for an aftermarket manifold and spending the extra time out boating insted of building one. A cast manifold should also run quieter
