ingnition switch wont turn motor off
marine11
I cant turn m y motor off with my key i have to disconnect the fuel line and let it run out of fuel to turn it off.
the switch turns on the motor although wont turn off the motor.
what seems to be the problem, do i need a new switch.
woody66912
Re: ingnition switch wont turn motor off
The stop curcit in the switch box has failed, you will need to replace it.
marine11
im not going to replace things just for the hell of it, i was told it could be the ignition switch also.
any way to test this
Dave1027
Check for a ground on the black yellow wire to the switch box. It should be getting a ground from the ignition switch when you turn it off. Probably a bad connection somewhere, even in the ignition switch itself.
CharlieB
Two wires on the ignition switch to check out.
Solid black is the ground and connects to the engine block thru the wiring harness to the ignition switch.
Second is the black with a thin yellow trace line is the 'Kill' wire, from the ignition module on the motor to the ignition switch.
The ignition switch connects the 'Kill' wire to 'Ground' when in the OFF position.
You could have a bad ignition switch, a poor contact inside the Cannon plug, or the ground to the engine block.
Start checking connections and use an Ohm's meter to verify the ignition switch.
