Info Tid-Bit......Engine breathing.
F_R
Re: Info Tid-Bit......Engine breathing.
No motor will run properly in a barrel with the hood on. Better re-think your advice.
sentinel
You have a point.
I took the precaution of placing a large fan at high speed aimed to blow exhaust away from the engine and provide fresh air to the singular opening around the steering opening.
But..... I need to recheck this suggestion apparently from what you are saying... so I will delete my original post until I am sure of the engine suffocation. Tnx.
