jbuote
Thread starter- Joined
- Aug 17, 2016
- 1,001
Hey All!
I've seen many posts from people saying they don't have a tach to check WOT range. For timing purposes, Prop testing etc...
Well, I don't either... So...
I have a 1971 Johnson 50 HP Hydro-Electric. It was non running when I got it. I've since fixed it up so it runs, and spent an afternoon on the lake with it fishing.
Had some issues with a misfire, so checked again, and found a crack in the #1 cyl coil.. I've ordered that. I've also decided I need a new prop!
Existing one is banged up pretty good, and I do believe the hub has spun.
With all that in mind, I ordered the coil, and an inexpensive Tach that I know I'm going to need to get things right. Especially when prop tuning to get the optimal prop.
I don't expect the coil to arrive until about July 3rd, but the Tach/Hour meter arrived yesterday.
So that's the back-story.. Now to the reason for this post.
Figured I'd start an ongoing review for this inexpensive Tach/Hour meter I bought here at iBoats and give an ongoing review of how it works/doesn't for my application. Maybe it'll help others if facing an "I don't have a Tach though" issue..
The Tach/Hour meter I bought can be found here:
http://www.iboats.com/Hour-Tach-Met...969931--session_id.219585622--view_id.1186148
Here it is as arrived:
Continued in next post.....
