impeller replacement question
atomb
I replaced the empeller and put new gaskets for water pump..
My question is When i put the upper an lower back together
I was under the impresion i had gotten most of the lube out.
but when i stuck the top unit back on the bottom some lube seemed to come out
This sounds dirty. anyway is this normal for a bit of lube to leak?
JustJason
Re: impeller replacement question
Well. Gear lube is very thick and if you gravity drain it you'll certainly have some extra. When you put the 2 halves back together did you remember to pick out the old, and install a new quad ring?
atomb
i havent tightened her up yet but i sure wish i new what you are talking about -pick out the old lube? no new quad ring what quad ring are you refeering to? Thanks for the input i appreciate it
JustJason
If the drive was installed on the boat. The quad ring is a very small rubber seal that sits on the lower half on the right side of it. They are typically orange, and can stick in the lower or stick to the upper if they've been in there a while. The upper and lowers share a common fill cavity, the quad ring fills that cavity. Downlaod the manual from the adults only section and have a read at it.
atomb
ok i really appreciate the help ---oil seal passage pretty obscure in the manual. Ill have to order one..thanks . the outdrive is not mounted when you say pick out lube can you be more descriptive .
JustJason
Read my first post very very carefully, then quote where I said to "pick out the lube"
You mis-read something.
atomb
:redface:my bad sorry about that. It was a long day I really appreciate you giving the advice and being considerate even when I was half assin it. Really my apologies. Thanks for not being a &^&%^&&% to me.
