78 MarkTwain
Thread starter- Joined
- Apr 10, 2012
- 15
I have a 1973 115 Johnson that I just started up (on the muffs) for the summer. Once the fogging oil burned up the motor seemed to run fine and was pumping water well. One thing I noticed was a sound coming from the lower end. I shut down the motor and turned the flywheel by hand and could here the noise was coming from the impeller. It sounds like the rubber is just making noise when rubbing up on the housing. I am just wondering if this is normal or should I be concerned there is something wrong? The impeller was replaced last year and I had the lower end off this spring and checked the impeller and it still looked new.
Thanks
Thanks
