impeller change on 2000 130 hp yamaha
grouper555
can anyone help with me with some assistance in changing this. i know basically what to do, but is there any one or a few things i should pay extra attension to help this job go smooth? how long of a job is this? thanks.
passingwindII
Re: impeller change on 2000 130 hp yamaha
go to youtube. stick in "outboard water pump" and watch. i believe theres 5 bolts around the lower unit and one thats under the rubber thingy on the rear top of the unit.
robert graham
Check: SIMYamaha-Andy's Tips, for step-by-step instructions and photos for water pump replacement and several other maintenance/repair items...very helpful information. I did my water pump for the first time several months ago and it wasn't nearly the nightmare job that I'd read about, as long as none of your bolts aren't stuck and break off! About a 2 hour job, first time. Order and replace the entire pump kit, not just the impeller. Good Luck!
grouper555
OK! thanks guys. you've been very helpful, more than u know.
