Impellar
FOO FOO
Hi I have a 87 16 ft. four winns 160 freedom that someone gave meI want to change the impeller. Do I have to take the upper and lower drive or can I just remove the lower. the boat is on a trailer and the stern drive is in the up position. Could I just drain the oil put the lower in the up position and take the lower off ? Also just how heavy is the lowwer part where the water pump is. Thanks Oh ya it's a 3.0 L
JustJason
Re: Impellar
Yes you can just drain the oil and drop the lower.
However a word of advice. The ujoints, gimbal bearing, bellows, and engine alignment should all be checked once a year. So depending on your gambleing luck, you might want to pull the drive to check things out.
Lower is about 50-60 pounds.
Re: Impellar
Ayuh,... Sure, it weighs about 40lbs per 1/2... 80lbs for the whole drive...
JustJason
Re: Impellar
I guess Bill's arms are a bit stronger than mine :) After this week of all the moving and driving, even the light boxes feel like they weight a million pounds right now!
FOO FOO
Re: Impellar
Thanks for the info. Justjason I noticed your from Dunstable MA, I grew up in Nashua. Live in Newburyport MA now. Thanks a bunch.
JustJason
Re: Impellar
I love Newburyport, such a pretty area. I'm dual residenting right now, i'm down in Cape Coral FL, haven't gotten around to changing my profile yet.
Don S
Re: Impellar
You never did say what kind of outdrive it is.
Re: Impellar
Ayuh,... Good point,.... ;)
I Assume, 'n I'm thinkin' JJ Assumes it's an Alpha.....:rolleyes:
I know,... I Know,....
Never, Ever, Assume....:redface:
ziggy
Re: Impellar
more than once i've commented only to find the op has a belt driven sea water pump. i've been learning to keep my mouth (keep board) closed till i got at least a clue to the op has..
