Impellar Placement on 65 hp Johnson Motor
davidgauldin
I have a 1973 Johnson 65 hp motor that i am replacing the impeller on .. I was wanting to know how can you be sure of which direction the impeller paddles should be bent .. Thank you
wilde1j
Re: Impellar Placement on 65 hp Johnson Motor
Which way does the flywheel rotate??
CatfishMN
I was under the impression there was no wrong way and that it will self correct?
