im new here and have a couple questions.
junglerooster1
hi everyone i just purchased a 1989 23' marathon and im having trouble identifying the motor and drive.
the motor is a I-4 and the valve cover says mercruiser 165 the model number is mcm165 and its a 224 cid no serial number and looked around on here with no luck. next the drive serial number is oB855519 any ideas?
please i need help because i need to order parts
thanx alot
junglerooster1
Re: im new here and have a couple questions.
my base seems to have some pressure build up what may be the causes?
i know the causes of my outdrive issues but i dont have a clue which outdrive i have are there markings on the drive unit?
Ayuh,... Yer motor is known as the 470, 'n yer drive should be an Alpha 1...
Download the top link below, there's a ton of great info in the Adults Only sticky at the beginning of this forum, click in there and have a look see.
Miscellaneous Mercruiser Information (from the adults only sticky)
How to ID an Alpha Style Outdrive, and History.
http://www.4shared.com/file/21385430...nd_Histor.html
This can be used to check the year of your engine, drive, and transom shield by serial number.
http://www.4shared.com/document/TcRI..._SN_range.html
BTW... sounds like the 470, which went by a few different models, I have the 3.7, same beast. Is an Mercruiser aluminum block, mated to a cast iron Ford head. One of a kind engine not ever used in a car or truck. Do some searchs on here for the 470, there should be several pages on em.
