ilde problem
artysniper
i have a 2000 90 hp johnson ocean pro , idles great on muffs, wont idle in the water after it gets warmed up and runs for 15 minutes , runs great at all rpms except for trolling idle, i had the carbs rebuilt this past fall, compression is all good . i took the boat to a mechanic last week and he could not find out what was wrong he put new plugs in , so yesterday i took the boat out for a test run and it would not idle again, so i take the boat home and try to start it today and the battery was weak and would not start the motor. i need some help .
Daviet
Re: ilde problem
What is your idle speed set at, in the water in gear?
Daviet
Re: ilde problem
It will idle at a lower speed in the water because of backpressure in the exhaust.
artysniper
Re: ilde problem
i understand this , is there a way to increase the idle on this motor,
