ignition
gibson31
newbie here,
just purchased used force 85 hp, cleaned lower unit, added oil etc
motor is out of boat , on a stand, so im trying to start with the harness dangling or whatever.
the choke engages when i turn the key but nothing else happens.
i searched this forum and found a thread about the neutral switch below the carbs, my linkage does come
near depressing that button, is this an issue ? how to fix
and wher is the circuit breaker and or fuses? ??
emoney
Re: ignition
On my later model 120, the main fuse is on the starboard side of the block. Describe more what you're saying about the neutral safety switch. Is it not engaging? If so, yes that's a problem is will cause you to not get spark. Verify your cables are all secure to the main wiring harness and the battery. And, of course, make sure the battery is fully charged and has enough CCA to crank the engine.
gibson31
Re: ignition
yes, now it is engaging,
and motor is now turning over
i dont have the throttle cable hooked up
will need accomplice or tender to start this
first time ever with an outboard
Jiggz
Re: ignition
Actually, just to get it started you do not even need a throttle although you can use what is referred to as fast idle. But if the motor starts and idle well, it should start just by choke first and then idles. While it's idling you can go back to the motor and play with the throttle. Just make sure you do not high rev it while on muffs or worse put it in gear.
gibson31
Re: ignition
say, it just started yea yea
but cut off
not sure if this starboard throttle is up or down (manually)
should i keep starting it at idle?
i just don know
hurry before the pizza gets here {just kidding}
gibson31
Re: ignition
but cut off
i just don know
at what point or duration does the WATER appear or flow thru
jerryjerry05
Re: ignition
Water should flow pretty quick if the hose has enough pressure????
In case??? I tape the muffs on.
Duct tape,on a dry lower.
If it doesn't have water in 30 seconds and your sure it has enough water.
Then the impeller should be changed.(I'd do it anyway)
