Ignition switch prob??
antat
If I test the ignition switch key off I have twelve volts on the same lead in if I turn the key I lose my twelve volt but pull the wire and I have twelve volt there again. Sorry if I explain this wrong I can answer question to help you better under stand mine thanks for taking the rime to read this I appreciate it.
NYBo
Re: Ignition switch prob??
Where are you connecting the negative lead for the voltmeter?
antat
I'm using the ground off the fuse strip.
Silvertip
Honorary Supreme Mariner
You said, [---I have 12 volts on the same lead in]. What lead are you measuring? If you have an outboard, +12 volts reaches the ignition switch on the "B" (battery) terminal. No matter what you do with the wire or regardless of the switch position, that wire will always read +12 volts unless the fuse at the engine is blown (which apparently is not the case here). The only internal connection on the switch with it in the RUN position is that the "A" and "B" terminals are connected. Therefore, if you have a very weak battery, any accessories that are active in the RUN position may be pulling battery voltage down. Ensure you have a fully charged battery and that is capable of actually holding the charge. Have it load tested at any auto store.
antat
Ok I have a Mercruiser 3.0 1987 and I have a fully charged battery and I'll look on the back of the switch but if I test the purple wire and I think a yellow switch on and start I have no power to them.
antat
Sorry the lead in is the orange wire of the fuse next to the switch
Silvertip
You lost me! I now have no idea what you are talking about. Look at the back of the switch. Each terminal has a letter next to it. Unless you give us specifics, we can't help. The switch terminals should be labeled "B" (+12 volts from the battery via the engine harness), "S" (starter solenoid) and this should show 12 volts only in the START position of the switch. "I" is the ignition position and should show 12 volts when the switch is in the RUN position. Now armed with that info -- what are we talking about? What color wire is attached to each terminal and what are you testing, and why are you testing? In other words, what is the real problem?
antat
Ok I'll try my best (s=yellow red stripe)(I=purple)(B=orange) ok this all started cause I had no spark so I tested the coil and key cranked I stopes below the 10v I was around 6v then I found a bad fuse replaced it started to check for spark again and everything stopes working no dash gages work. but the pump nav lights and air pump still work. So I was checking for power in and that's where it seemed to lead me to the ignition. Key on the on position no power at any leads I s b same with key turned to start but key off I have 12.3 v on the B till I turn the key to on then I have no volts that's the orange wire b term. I sorry I'm trying to explain the best I can and I thank you for all your help.
