mercuryman80
Thread starter- Joined
- Oct 25, 2012
- 30
Well the boat ran good in the spring , then lacked power. I checked ignition and had no fire on 3,4 switchbox and stator replaced then noticed white wire from trigger oem was totally junk all the way to the housing on trigger , pull flywheel off again replace trigger , now I have spark on 3,4 but arcing plug wires --changed plug wires crimped some new ones with new plugs and no change , checked all coil grounds to motor,coil,cowling nd battery cleaned and reground wires- no change everything seems to check out on the dva meter but stll have arc on all cylinders and can tell by sound of motor,,,, I'm so lost and frustrated any help wold be greatly appreciated tks to all who contribute
