Ignition johnson 15r74g
polotche
Hi,
I want to known how to check my ignition on my 1974 johnson 15hp because I have no spark
thanks a lot
sorry for my language I m french
Remove flywheel.----Clean and set points at 0.020".---Test for spark again.-----No money spent test.
polotche
ok
thanks racerone, I testing this and I'm telling you again
Crosbyman
Hre are few instructions in French ….
première chose à faire c'est de débrancher le bouton d'arrêt qui peut-être défectueux et tuer l'ignition
il faut retirer la tête et aller nettoyer les pointes avec de l'acetone et une carte d'affaire ou pièce de papier rigide
il faudrait spécier si ce problème est apparu soudainement ou progressivement
il est rare que les deux circuits d'ignition tombent en panne ...ceci est indicatif d'un problème commun alors vérifiez bien le bouton d'arrêt
http://www.leeroysramblings.com/johnson_magneto.htm
polotche
Thanks Crosbyman
I buy this motor in out of order. So I search why it does not start
You are asking for some help.------" I tested this and i'm telling you again "-----What do you mean by that statement ?------Bring it over as I have everything that you might need to fix it .----No need for me to buy any parts to fix that simple motor !
polotche
We don't understand. I remove flywheel tomorrow and clean point. I will give you the result
oldboat1
Utilisez des condenseurs à pointe noire plus récents. Assurez-vous que les points sont parfaitement propres - l'acétone est un excellent nettoyant, appliqué avec une couverture d'allumettes.
polotche
HI,
I clean the point with acetone and set the points but I have no spark again.
I see the capacitor and the point are news
I join a photo
Crosbyman
follow up… did you yes or no remove the kill switch and retest
did you yes or no … measure the coils secondary & primary resistance with a ohmmeter... post the values
did you yes or no .. inspect and/or redo / clean all wiring connections
did you yes or no try new plugs
Crosbyman
btw the top left corner of the coil looks burnt ???? if it is…... the secondary winding may be shorting out to ground …. or it could be jumping from the coil laminate to the flywheel ???
remove the coil and test the windings to see if the coils are shorted to the laminates ...measure OHMS between wires and laminate should see open .. infinite ….. nothing whatsoever
That does not look like an original style driver coil.-----So is it the correct replacement ?----Or something else.-----Is there a part # on it ?
F_R
Just for the record, there is no secondary winding in the driver coil. That all happens in the external spark coils
oldboat1
I see serious top abrasion (coil) from flywheel contact. The coil also appears to be in contact with the condenser (top of picture -- burnt area that Crosby mentions.)
I think the driver coil is either the incorrect one for your model, or is installed incorrectly. If there is a machined area on the mounting post, the edge of the coil lamination must be perfectly flush with the flat machined area.
[Edit. The BRP driver coil for your motor is part number 763784, and is available here at iBoats. The correct coil mounted correctly insures that the critical air gap to the magnet is correct]
polotche
I will try to answer everything The spark plug are news, the number of the driver coil is 511441
I measured the resistance and I find 0.5 between the primary and the secondary
1.6 for the primary
1.5 for the secondary
The coil touch the flywheel so I moved it
this ignition was tinkered before me so I try to do better
I say that is the wrong coil !!----You need a DRIVER COIL and only used on motors in the early / mid 1970's
Crosbyman
F.R... true re driver coil and … I looked at the parts diagram
crow pie again...
polotche
I will buy a new coil drive with the good reference and I will tell you
