I'm fixing a rope start tiller 15hp Johnson 2000 for my brother that he got for nothing and have everything put together now and tested it and got no ignition. I tested it with my home made 8 cylinder spark tester and found that only the bottom side of the Ignition coil is firing/sparking. I changed the spark plug wires to a set from another engine I know are good and got same results. I switched around the primary wires coming from the power pack and still only got spark only from the bottom bank (this is the type of coil that has two banks (see picture). Is there any other possibility that this coil may be good and the problem is elsewhere?
