john from md
- Apr 13, 2008
- 2,184
I just recently purchased a 1985 Bayliner with a Force 85hp engine. From the start, I have been experiencing high charging voltage. I did some research on this subject and decided to do my own testing. All of my connections are clean and my batteries terminals were as well.
Several people on the web have stated that, since the alternator only delivers 9 amps, it cannot harm the battery. Others stated that the problem was that the battery terminals were corroded or the battery was shot. I wanted to find out the real story.
On Friday, I installed a brand new Exide Marine 730 amp battery. I had previously checked, water lever, specific gravity of the fluid, voltage and did a high rate test on it. This battery was new and in great condition. As stated before, all of my wiring is also in good condition.
Friday, the Chesapeake was pretty calm for this time of year so I ran around for 1.5 hours with no particular destination. During this time, my volt meter read 16.5 volts. At the end of this time, I opened the battery box and found water puddled around the battery. The sides of the battery were warm and the voltage read 13.9 volts.
I suspected that overcharging was occurring as I found water in the battery box before. At that time, the box cover was not on and I thought that it might have been water splashed in from that damn swim platform that floods the boat constantly. However, I took the swim platform off for this trip and no water came into the boat.
Since several people on the net had replaced the rectifier and experienced no change, I decided to put in a regulator instead. The regulator part number is Universal 090-5. It is made for an ATV but will work on the Force engines. I obtained this information from several posts where the posters had the same problem and the regulator corrected it. The reported voltage after installing the regulator is 14 volts. In years past, I have done the same thing with Suzuki and Honda motorcycles and it also served to bring the excessive voltage down.
The regulator costs $45 but I feel it is well worth it. Batteries are not cheap these days and I want mine to last as long as possible. Additionally, I don't want to be in the middle of the Chesapeake and hear click, click when I turn the key.
I hope this helps some of you with charging problems. For what it's worth, I am a professional aviation mechanic.
Regards,
John
Regards,
John
