Idle problem with 96 5.7 2bbl
Status
Not open for further replies.
fishingman220
Re: Idle problem with 96 5.7 2bbl
so should i take the carb apart and empty it, or not??? i will get new cap rotor, new wires and plugs, anything else?? should have the carb looked over again???
Don S
You may be able to clear the carb, but you really need to understand what I am saying first.
1. Hook up a remote fuel tank that doesn't have any water in it, and new fuel. (Outboard tank)
2. Put on a new filter.
3. Disconnec the throttle cable from the engine, and remove the flame arrestor.
4. Start engine (on muffs of course). You will need a helper to start the engine while you operate the throttle linkage at the carb.
Don't stick your face over the carb.
5. Here is the trick. You need to raise the engine RPMs up to around 4000 to 4500 rpm (By sound, you won't have time to be looking at the tach). Just as it gets to the higher rpm, with your other hand completely close the choke and open the throttle wide open. The engine rpm will drop quickly, just don't let the engine stall or it will be flooded and a pain to restart. Do this several times, it wil pull the water out of the carbs bowl.
Keep in mind, to high an rpm and the engine blows up, to low and it won't work.
fishingman220
ok thanks, so how did you come to know all of this????
Don S
I'm a marine tech, I do this stuff for a living and have been for more years than I care to admit to.
SuperDaddy
I'd just like to point out as an innocent bystander to this thread, that I appreciate the info I learned from your posts, Don. Thank you.
dusty456
I am new to this site and read all these threads. Some very sharp guys out there. I hace the same problem with idle but on a efi 350 merc. Anyone able to help?
krisnowicki
Is this cool to do on muffs or should it been in the water...?
Ayuh,....
Welcome Aboard,...
Rule #1 in forums is,...
Start a thread of Your Own, with all the pertinent Info about Your motor,+ drive in it...
Never Hy-jack somebodyelse's thread....
Status
