Idle/fuel problems with 1970 60 hp evinrude 3 cyclinder
mhamilton28
I have the above engine with idleing problems. I have replaced the entire ignition system over the past year and fuel pump. Staring not usually an issue. It will surge and then back off repeatedly at idle. It will also only get up to about 2300 rpm in gear and tops out around 8mph. I have replaced the fuel connector to motor. I have tried to adjust the slow idle and it is not missing. Will your squeeze bulb stay firm when engine is running? I have thought about replacing the entire tank tubing . Anyone have any ideas. I do have the manual for it.
thanks
