astuckey
Thread starter- Joined
- Sep 4, 2011
- 83
Hi, I have a 4.3 cobra, that has had idle problems, since I installed the pertronix ignitor 2 module. The timing is set correctly, and the ignitor 2 module is hooked up to the alternator, at a switched source. Interestingly, the problem only happens when the engine is not completely warmed up yet. Also, I looked at the magnetic pickup, and the ignitor module, and both had wear on them. It looked as if there was no gap between the magnetic pickup, and the ignitor. I GENTLY applied pressure to the ignitor to try to bend it back, and got a slight gap. Same problem. I called pertronix, and they said that the slight, or no gap wouldn't affect the preformance, it would only cause the pickup and ignitor to wear. I put an inline spark tester on a few cylenders, and the spark was sometimes strong, sometimes weak, and sometimes, no spark at all.
Has anyone else had this problem?
Also, I have a prestolite, IBM 7021 distributed, and a ignitor 2 #91563B
Any help would be greatly appreciated!
Thanks
Thanks
