Identifying year Model
jgwade99
I have a Johnson 6HP motor and the cowling/cover has been lost. How do I identify the year model and model number of this outboard motor? I would like to try and find a cowling for it, but before I do, I'm sure I'll need the info requested. Any help provided will be greatly appreciated.
Thank you,
Greg
KB_85_V20
Re: Identifying year Model
is there a small plate on the port side of the mount? thats where mine is but its much larger(200).
jgwade99
I won't be able to check for the label until this weekend. Will provide an answer then.
gazza2007au
u can just write down a part number from the engine and look it up just type into a internet search bar "johnson 6hp 094281" and it should pop up the year model
jgwade99
I don't know any of the part numbers. I thought if I had the year model, then I would be able to determine the part number for the cowling.
jgwade99
I finally had the opportunity to check out the motor this weekend. On the transom mounting bracket, I found this information:
Model No. J6RCRM
Serial No. E5873093
Can somene help me determine what year this motor was manufactured?
Thanks in advance,
Greg
bankerjohn
J6RCRM = Rope start 1984 6hp Johnson (the "CR" part is the year of manufacture)
INTRODUCES
1234567890
jgwade99
bankerjohn,
Thank you so much for your reply. My next question is if anyone knows where I can find an engine cover for this engine?
Thank you,
Greg
bankerjohn
Here's a link to a motor just like yours that was sold ... thought you might like to see what the cover is supposed to look like!
http://www.smalloutboards.com/e684.htm
Suggestions for finding a cover ... eBay and Craigslist ... local marine repair facilities ...
