RotaryRacer
- Jul 18, 2004
- 1,361
Re: I want a boat....But don't have any clue what I should get
From experience.
Several years ago we got a Zodiac Cadet 340 FR...that is an 11' boat with an air floor that can be folded up and transported pretty easily. It is rated for 15HP. This is a pretty similar boat the to Saturn SD 330.
At the time we had a 1968 Evinrude 9.5 hp motor. The motor would just barely get the boat up on plane when there were two people in the boat. With one person the boat would go maybe 15 mph tops. That same motor would push a 12' aluminum boat about 20-22 mph. The aluminum boat has a lot less surface area in the water when on plane and glides through the water a lot easier.
We upgraded to a 90s 15hp Mercury for the Zodiac soon there after. Now this thing started to be fun. The boat would easily plane with 2 people and would run about 20 mph with two people. It could get on plane with 4 light adults but it was struggling to do that. With one person the boat would hop on plane really easily and would scoot right along. It would become airborne at the slightest wave. If the motor was tilted right and the driver was willing to kneel in the back of the boat and hold on it could run with just a the rear of the tubes and the keel in the water. It was fun. A PFD and kill lanyard was a must. I never flipped it but came too close for comfort several times. Running this boat in this manner was really hard on it. It was not designed to be run hard. It was intended to be used as a tender/dinghy. It has required some repairs but it is still useable and seems to have held up ok.
You need at a minimum 15hp for an 11' boat to have any "fun". If you go to to a 12' or larger boat you will want more power.
Johnsons and Evinrudes are pretty easy to get and are dead realiable in the 15hp size. I would get something from at least the mid 70s. The same basic motor was used all the way into the 90s.
If you want a Mercury I would get one that is a little newer one (late 80s early 90s) if you can afford it.
From experience.
