I put it in reverse my engine flips up
dominic81
I put the engine in reverse and my engine flip's up what could be causeing this? It is a thunder bolt 850 85 hp.
JB
Re: I put it in reverse my engine flips up
There is a mechanical linkage between the shifting linkage and the outboard anti-tilt linkage. The anti-tilt should lock the engine down when you shift into R. Look under the cowling for this linkage while you move the shifter. Needs adjustment or something is broke.
Wingedwheel
Or stuck and needs lube. Have you had the LU off lately?
