I need to replace 79-(228) v-8 with ?
osborne looney
i am kind of new to the I/O'S have worked on plenty of outboards -- i just picked up 79 century 20' with a pretty badley cracked block (both sides) from ice i would presume -- from what year to what year can i replace this with little as possible ? also can i use a higher hp 6cyl ? 190hp they seem to be more available for some reason any help would be great thank you :)
haulnazz15
Re: I need to replace 79 v-8 with ?
We need to know what the current "cracked" block is. The outdrive you have is likely geared for a V8, going to a V6 might require a different outdrive ratio. You don't want to drop down to a V6 anyway.
osborne looney
cracks are beyond repair i believe cast is pushed out in a circle or horse shoe about 4" diameter so i guess i will look for a good 228
osborne looney
cracked is a 228
Fishermark
And what is a 228?
osborne looney
305 chevy 228 hp i believe ? can not got a good ser # 1/2 seems to be worn off
Fishermark
Easiest solution is to replace with another first generation 305 - or even 350. Keep it to an older two piece rear main. Be sure to check the condition of the manifolds and risers as well.
haulnazz15
The 228 was 4bbl Chevy 305 I believe. I would replace it with a 350 since it's almost a direct swap, parts-wise, and you'l get another 30-40HP in the process.
Fishermark
If you have good accessories that you can transfer over, then a universal crate engine is a good deal. You can transfer your marine externals and are good to go. I believe these crate engines even already have brass core plugs and composite head gaskets - but you can check. You can get them various sites for around $1,500. Here's an example.
osborne looney
like everyone else wants reasonable i only paid 500 for complete boat trailer ect . if i could find a long block for 500 or less i would go that route or good used that i could hear run before buying it might take some time but season is winding down
osborne looney
like i stated earlier i am kind of new to i/o's what years 305/350 can i install with lil or no problems
anyone in n.w wisc has a pre 85 marine 5.0 or 5.7 reasonable
Fishermark
As mentioned above - get another engine with a two piece rear main - basically anything before 1985.
