I need specifications for alternator mercury 15hp model 2010, please help!
cpescar
Hello, please help me i need specification for my alternator (stator) and i don't find anywhere.Engine is 15 hp model 2010 four stroke (short)
I know from technical book "alternator amp 12 amp/138 watt" but need moore like : volts( real, in heavy duty not whithout electrical consumer), in full throttle and in minim (relanty( 900 rotation /min) or anythink else specifications, moore that "alternator amp 12 amp/138 watt" . need also if you known specification for rectifier / regulator !
thank you very much! and please again
Laddies
Banned
Re: I need specifications for alternator mercury 15hp model 2010, please help!
12 amp is at WOT Any continuity through the stator wires and none to ground the stator should be good. The rectifier should test similar to these.
