I need expert advice (not the manufacturers)
Status
Not open for further replies.
ClintGerus
Hi,:)
I'm new to this forum and am impressed at the knowledge I have read herein.
I have a 1969 (I think) Mercury/kiekhaefer 500 (50hp in-line 4)
In the manual (yes, came with the motor) it tells me to use 50:1 if I use the "Mercury formula 2 oil" (Witch I cannot find anywhere) and If not available, to use an approved oil at 20:1!!!
I assumed by "approved" they mean TCW-3 rating.
I have run 3 tanks of gas at 20:1 (1 litre of Tech 2000 for 20 litres of gas)
and have experienced some problems;
When wide open, it seems to run great... not too smokey, sounds good, runs full speed (about 30-35mph on a 1969 14 foot fiberglass Vaguard)
But it won't start without the choke (unless it's hot already)
If I put it in gear (reverse or forward) at idle speed, it will go but if I give any gas, it stalls.
I find that I need to use the slow idle speed lever to boost the rpm's THEN get the boat moving in gear before I can give it any throttle.
I pulled the old plugs when this first started to happen and found that 2 plugs were decidedly carbon'd up (While the other two seemed "clean")
unfortunately I failed to note if the two fouled plugs were working o the same carb.
There old plugs were 20 years old, so I put in new ones and will take them out next weekend to check if the condition is persisting unless one of you experts tells me it's something else. (It has only been maybe 3 hours of boating on the new plugs... stalling problem still exists)
Is this just Mercury trying to get people to use "their" oil or should I continue to run that thick 20:1?
All the oil-mix advice I have read on this site has stated 50:1 for this vintage... That's what the book says (as long as I use that oil I can't find)
Any and all advice is greatly appreciated!
I am willing to e-mail out the scanned original manual (if anyone needs it)
Thanks in advance,
Clint Gerus
diaric
Re: I need expert advice (not the manufacturers)
duplicate post
JB
50:1 with any TC-W3 oil will do fine, Clint. They didn't have TC-W3 in 1969.
Do not send out scanned copies of the original manual. That would violate federal copyright law.
Status
