guy48065
Thread starter- Joined
- Aug 31, 2008
- 575
My 79 Crest--nicknamed "Frankenboat" by the previous owner--had the gear control action reversed. Push forward to reverse, etc. Last weekend I took it apart & switched the cable to the other side of the bellcrank and now it works correct...almost. Problem is it "sticks" near WOT. The throttle never did this before so I don't know why moving the shift cable would have any effect on the throttle. With the end disconnected from the motor throttle lever I can move the control smoothly from idle to WOT but when I pull it back it hesitates, then snaps about an inch. In use that feels to be about a 2000 rpm drop and if anyone is standing it can pitch them forward.
A co-worker suggested Frankenboat might not have the control cables properly secured. I'll have to check this weekend but I need to know--what is "properly" secured?
