robbie419toledo
Thread starter- Joined
- Jul 2, 2009
- 3
i would really appreciate some expert advice!!!!! obviously the engine will have to come out . do i need to remove the outdrive ? as far as i can tell only 3 bolts hold the motor in place 1 in front 2 in the back, the wires, and fuel line. should i remove the fresh water intake due to clearence?(a friend had the same problem on an identical boat and he cut out his live well! i don't want to do this) i heard also to tilt the bow up so it will come out easier is this a good idea? also swingset or engine hoist does it matter? how much dose the out drive shaft engage the coupler? thanks in advance Rob.
