I greased the steering and then it seized up
sly_karma
1974 Starcraft Holiday with an 88 Evinrude 40. Been on or near salt water for a dozen years. Family isn't big on maintenance, I brought it home to replace the windshield and get a moorage cover made. Thought I'd do the right thing and lube all the usual spots: steering pivots, tilt tube, shift/throttle cable linkages. I replaced the old spring and wire steering 6 years ago with Uflex cable, has been working fine. Decided to smear a film of grease on the cable end at the tilt tube. Worked it back and forth a few times and then moved on to other work. An hour later I wanted to move the engine to one side and found the steering was now completely seized up solid. Disconnected the linkage from the motor; the cable is frozen in the tilt tube. Had to hammer it out with a drift pin, needed to remove engine mount bolts and move it sideways to get the cable out of the tilt tube. Cable continues to operate freely, but is not a good fit into the tilt tube. There appears to be some kind of rust/grease emulsion in there that has set into a clay-like compound. Anyone seen this before? And if so, how do I remove it and return my steering setup to its former reliability? I'm baffled that lubrication had caused something to seize.
Ayuh,..... Just did this,..... Went to a Hvac store, bought a boiler cleanin' brush, cut it down, chucked it in my cordless drill, 'n buffed the 'ell out the tube,....
oldman570
I did something similar as Bondo . I took a 3/8 piece of wood rod , cut a slot length wise down the center of the rod about 2 inches and placed long tape sandpaper in the slot. It made a form of sandpaper floppy wheel that I chucked up in a drill and cleaned the crud out of the tube. Using paper shop rags soaked in brake clean, or other cleaner, to get some of the hard crud and grease loose first helps things go faster.
