Glastron_T156
Thread starter- Joined
- May 29, 2009
- 11
As I mentioned in the previous posts, this is 1977 55HP Johnson SeaHorse. New fuel line, tank, fittings, fuel pump. Carb cleaned three time with new kits and new jets. New spark plugs. New water pump and oil changed.
The motor starts ok, two three times will fire it up, runs great at low speed (up to 15 mph) and reverse, I can run all day long with that. But the boat/motor combination really should give me about 30 mph.
The problem is: the motor bogs down at full throttle; the spd will go down to 10-12 mph from 15 mph. and will back to 15 mph after I pull the throttle back a little bit.
A mechanic said that the timer base sensor, stator and power pack are bad. I am trying to eliminate at least one of these three now. As learned from here and classicglastron website, I bought a DVA adaptor with a fluke 27 multimeter and did some tests last weekend, here are the measurements:
1. Sator resistance test: at terminal block,
stator lead yellow to ground: infinity; gray to ground: infinity;
yellow to gray: 1.0 ohm (service manual value: 1.0-1.6 ohm).
Pass.
2. Rectifier test: test all at terminal block, manual said one direction is zero and the other director is infinity. But I did not get anything like that. All the tests I did are the same on both directions with different values on different leads (yellow/gray (1.1), yellow/blue (0.0), and the rest are infinity), here is my question: what dose rectifier do? Am I testing right? If this one is bad, can the motor run well at low spd?
3. Sensor coil resistance check:
at power pack terminal 6 and 7, reading 16.8, manual suggests 10-20 ohm.
Pass.
4. Charge coil resistance test:
power pack terminal 1 and ground: reading 797, manual suggests 675-825 ohm.
Pass.
5. DVA test: since the manual uses neon light, I lost instruction, and found some info from this forum and outboardignition.com. I did all the DVA measurement on the power pack with motor running in the lake while the boat was tighten on the dock.
6. Charge:
browen terminal 1 to ground: got 10 v first, and somehow then got 210v, after fishing back, got 10v again, running the motor to full throttole, the voltage dropped down to 6-7v (now I am not sure if that is terminal 1 or 2).
I may have redo this again. My question is if the voltage is 10v, can the boat run well?
7. Trigger:
white/black and black/white terminal 6 and 7:
6 to ground: 10v,
7 to ground: 10v, Is this value ok? Outboard said should be close to what is read on stator, what is the read on stator, how to check that?
6 to 7: 2.1v (> 0.5v will be OK)
I did not test ignition terminal 2 and 3 to the ground, do I have to, what dose that mean?
I need help on interpreting these measurements, which part is good and which part is bad? Any other measurement I need conduct?
CDI suggested disconnect rectifier and retest, how do disconnect rectifier? Can the motor still run without rectifier?
Previous posts details here:
http://forums.iboats.com/showthread.php?t=317782
http://forums.iboats.com/showthread.php?t=321539
http://forums.iboats.com/showthread.php?t=337820
this is the longest post I ever write, hope I explained all what I did and hope I can get some help form your guys.
Thanks a lot.
btw, the flywheel seems running ok with a small chip-off yesterday.
Pass.
Pass.
Pass.
6. Charge:
7. Trigger:
6 to ground: 10v,
Thanks a lot.
