I.D this drive?
ledsled
A couple of years ago, I traded for a 1971 Monark 17' aluminum tri-hull project boat. Due to other projects, I will probably sell or trade this one. I'm trying to I.D the drive so I can give someone an answer if asked. S.N on the drive is 2727781. Any help appreciated and thanks in advance.
Don't know where the pics went...will try again later
Bt Doctur
Re: I.D this drive?
If we had a clue as to what manufacturer we might give an answer.
ledsled
Re: I.D this drive?
Bt Doctur
Re: I.D this drive?
67-69 Series1 , 120/140Hp, had the early trim cylinder setup with the lines that joined up just inside the housing,
later model`s has the hyd. lines at the junction block at the bottom of the transom housing.
