Re: i broke down and did it... i bought SMART TABS
BTW, we went today for and hour and a half, The boat, since I adjusted to the least pressure point on the bottom bracket
my boat is new and light anyway and didnt have a problem getting up to begin with, so my best result from he Taba has been in stability with slight better up to plain. The bow is now slightly higher at WOT, and so doesnt feel pushed down as much before the adjustments. I think I will run like this a bit
. We did notice I had a slight list to port, so I am going to drop the Tab down from the port side slightly, and see if this lifts her up a bit. The stability from side to side rolling while negotiating wakes is greatly increased, and we feel safe. Also high powered sharp turns (if the drive is trimmed down slightly) grab the water very well
more stability.<br /><br />With two people in the boat, a heavy tool box in the back starboard side, at wot we were 4800 rpm at 46 mph, the exact stats from boat. Before the adjustments to the pressure bracket, the bow was too far down IMO, but with three people in the boat, at wot, we achieved 45 46 mph at the same rpm, yet the bow seemed to be low to me. My adjustment went from the mid point, all the way to the easiest setting. I may back a bit toward the mid point a ¼ on both tabs. And drop the port Tab deeper into the water (from the top bracket) in order to cure the list to the port as we may have been a degree or two off from one to the other, during the original installation.<br /><br />These adjustments will be made before we go out again on Sunday.
