Jdeagro
iboats.com Partner
- Jul 30, 2003
- 1,682
Re: i broke down and did it... i bought SMART TABS
myoutboards;<br /><br />The ST1290-80 indicates that the plates should be 12"X9" and the actuators should be 80Lbs. The 80 Lbs actuators are very stiff and unless they are not 80 lbs (an error) they should not allow the stern to drop on shut down. Check the angle of deployment at rest (25 degrees or about 3" down at the back edge of the plate). Also pull up on the plates to get an indication of the strength of the actuator. This should take some effort.<br />The splash in the back could be from the water flow off the side of the plate hitting the motor. The pictur indicates that you would be better moving the platres further out. I would suggest that you not re drill all of the holes just index the plate two holes toward the outsides and the remount the upper bracket. This way you will be using three of the existing holes.<br />Leave you phone number on our e-mail and I will be happy to call. info@nauticusinc.com
